Skip to content
Values and methods for build event handlers
Build event handlers have access to the following values and methods.
Each event includes a constants key.
src/index.ts
import { NetlifyExtension } from "@netlify/sdk";
const extension = new NetlifyExtension();
extension.addBuildEventHandler("onPreBuild", ({ constants }) => {
console.log(`The project id is ${constants.SITE_ID}`);
The constants key contains the following values:
  • CONFIG_PATH: path to the Netlify configuration file. undefined if none was used.
  • PUBLISH_DIR: directory that contains the deploy-ready HTML files and assets generated by the build. Its value is always defined, but the target might not have been created yet.
  • FUNCTIONS_SRC: directory where function source code lives. undefined if no netlify/functions directory exists in the base directory and if not specified by the user.
  • FUNCTIONS_DIST: directory where built serverless functions are placed before deployment. Its value is always defined, but the target might not have been created yet.
  • IS_LOCAL: boolean indicating whether the build was run locally or on Netlify.
  • NETLIFY_BUILD_VERSION: version of Netlify Build as a major.minor.patch string.
  • SITE_ID: Netlify project ID.
Along with these constants, build event handlers can also access any of the environment variables that are available in the build environment.
If your build event handler requires additional values from the user, you can specify these requirements with a configuration schema that defines what kind of values these should be. These requirements are defined using Zod. Users can then supply the required values in their netlify.toml configuration file. These values can be used inside of your build event handler, or to create dynamic build event handlers.
Try the extension UI
Instead of using buildConfig and asking users to configure your extension in their netlify.toml file, you can instead use the extension UI to let a user configure your extension from the Netlify UI.
To make a schema using Zod, import { z } from "@netlify/sdk".
Then, use z.object to define what kind of values you expect from the user of your extension. For options, refer to the Zod documentation. Zod automatically ensures that the values a user provides are valid. It also adds typing, so you can be confident while you use the values in your buildConfig object.
src/index.ts
import { NetlifyExtension, z } from "@netlify/sdk";
const buildConfigSchema = z.object({
output_path: z.string().optional(),
fail_deploy_on_score_thresholds: z.boolean().default(false),
thresholds: z
.object({
performance: z.number(),
accessibility: z.number(),
"best-practices": z.number(),
seo: z.number(),
pwa: z.number(),
.optional(),
const extension = new NetlifyExtension({ buildConfigSchema });
extension.addBuildEventHandler("onPreBuild", ({ buildConfig }) => {
console.log(buildConfig.output_path);
console.log(buildConfig.thresholds);
A user then supplies the required values in their project’s netlify.toml file:
netlify.toml
[[integrations]]
name = "extension-slug"
[integrations.config]
output_path = "reports/lighthouse.html"
fail_deploy_on_score_thresholds = "true"
[integrations.config.thresholds]
performance = 0.9
accessibility = 0.9
best-practices = 0.9
seo = 0.9
pwa = 0.9
These values are passed into the build event handler’s buildConfig when the build handler is executed.
When an event executes, a project’s Netlify configuration is normalized by @netlify/config and passed to your build event handler as a netlifyConfig object. Normalization includes applying context-specific or branch-specific settings and combining settings from netlify.toml with build settings configured in the Netlify UI.
After normalization, build event handlers can access and modify most netlifyConfig properties during a project’s build. These include redirects, headers, and build configuration. If a project doesn’t use netlify.toml or build settings selections in the Netlify UI, netlifyConfig and its properties contain default build settings.
Here’s a list of modifiable properties:
Here’s a build event handler code sample that modifies several of the above properties.
src/index.ts
extension.addBuildEventHandler("onPreBuild", ({ netlifyConfig }) => {
const newCommand = `node YOUR_SCRIPT.js`;
// Run a script after the build command
netlifyConfig.build.command = netlifyConfig.build.command
? `${netlifyConfig.build.command} && ${newCommand}`
: newCommand;
// Modify the build command’s environment variables
netlifyConfig.build.environment.DATABASE_URI = getDatabaseUri();
// Add redirects
netlifyConfig.redirects.push({
to: "/DESTINATION_PATH",
// Add headers
netlifyConfig.headers.push({
for: "/YOUR_PATH",
values: { YOUR_HEADER_NAME: "YOUR_HEADER_VALUE" },
// Add edge functions
netlifyConfig.edge_functions
? netlifyConfig.edge_functions.push({ path: "/YOUR_PATH", function: "YOUR_EDGE_FUNCTION" })
: (netlifyConfig.edge_functions = [{ path: "/YOUR_PATH", function: "YOUR_EDGE_FUNCTION" }]);
Each event handler includes a packageJson argument. When an event handler executes, the contents of the package.json in a project’s base directory get passed to the build event handler. The data fields are normalized to prevent build event handler errors. If the project has no package.json, the argument is an empty object.
To access the packageJson object in your build event handler code, use the following pattern:
src/index.ts
extension.addBuildEventHandler("onPreBuild", ({ packageJson }) => {
console.log(packageJson);
Build event handlers can access build environment variables two different ways:
  • process.env: includes all Netlify build environment variables and any variables a user declares using the Netlify UI or netlify.toml. We recommend you use this when you only need to get values during the build process.
  • netlifyConfig.build.environment: includes only the variables a user declares using the Netlify UI or netlify.toml. We recommend you use this when you need to modify values during the build process.
Visit our Forums for a verified Support Guide on how to access environment variables during a project’s build.
We’ve provided a number of utilities and API methods to assist you in writing your build event handler.
Build event handlers can fetch data from an extension endpoint. The built-in extensionEndpointFetch method has all of the necessary headers set so that you can make authenticated calls to your endpoint.
extensionEndpointFetch accepts the following parameters:
  1. endpoint (string, required)
    • The endpoint path to be called (for example, .netlify/functions/hello-world)
    • This gets combined with the extension URL to form the complete URL for the fetch request unless the endpoint starts with http or https.
  2. init (RequestInit, optional)
    • Standard fetch initialization options including: method, body, headers, etc.
    • Any headers specified here will be merged with the automatically added Netlify extension headers
    • Example: { method: 'POST', body: JSON.stringify(data) }
Returns a Promise<Response> just like the standard fetch API.
The following example adds an endpoint and a build event handler that retrieves dynamic data from that endpoint.
  1. Create an endpoint under /src/endpoints/ that returns some data for use in your build event handler:
src/endpoints/hello-world.ts
import { withNetlifySDKContext } from "@netlify/sdk/ui/functions";
export default withNetlifySDKContext((req, context) => {
return Response.json({ data: { greeting: "Hello, world!" } });
  1. Next, create your build event handler and let it query your new hello-world endpoint for data using the extensionEndpointFetch function:
src/index.ts
extension.addBuildEventHandler("onPreBuild", async ({ extensionEndpointFetch }) => {
try {
const res = await extensionEndpointFetch(".netlify/functions/hello-world");
const resp = await res.json();
console.log({ resp });
} catch (error) {
console.error("Error fetching data:", error);
export { extension };
Don’t use the global fetch function to perform requests to endpoints
Note that this example uses the extensionEndpointFetch implementation provided by the SDK through rather than the global fetch. The SDK extensionEndpointFetch implementation ensures all of the necessary headers are set so that you can make authenticated calls to your endpoint.
One of the arguments passed to the build event handler is a client object. This client provides interfaces that allow you to do the following:
  • interact with the Netlify API or the Extension API
  • read and modify extension state relating to the current project or team
For information about available methods, review the NetlifyExtensionBuildClient API reference.
Several utilities are provided with the utils argument to event handlers:
  • build: used to report errors or cancel builds
  • status: used to display information in the deploy summary
  • cache: used to cache files between builds
  • run: used to run commands and processes
  • git: used to retrieve Git-related information such as the list of modified, created, or deleted files
src/index.ts
"onPreBuild",
async ({ utils: { build, status, cache, run, git } }) => {
await run.command("eslint src/ test/");
Exceptions thrown inside event handlers are reported in logs as bugs. Instead of using the onError event to handle exceptions, build event handlers should rely on try/catch/finally blocks and use utils.build:
The following methods are available depending on the error’s type:
  • utils.build.failBuild("YOUR_MESSAGE"): method that fails the build. The build in the user’s dashboard would show “Failed”. Use this to indicate something went wrong.
  • utils.build.failPlugin("YOUR_MESSAGE"): method that fails the build event handler but not the build.
  • utils.build.cancelBuild("YOUR_MESSAGE"): method that cancels the build. The user’s dashboard would show “Canceled” for that build. Use this to indicate that the build is being canceled as planned.
utils.build.failBuild(), utils.build.failPlugin() and utils.build.cancelBuild() can specify an options object with the following properties:
  • error: original Error instance. Its stack trace will be preserved and its error message will be appended to the "YOUR_MESSAGE" argument.
src/index.ts
extension.addBuildEventHandler("onPreBuild", ({ utils }) => {
try {
badMethod();
} catch (error) {
utils.build.failBuild("YOUR_MESSAGE", { error });
Anything logged to the console is printed in the build logs.
src/index.ts
extension.addBuildEventHandler("onPreBuild", () => {
console.log("This is printed in the build logs");
If you’d prefer to make the information more prominent for users, use utils.status.show() to display information in the deploy summary instead.
src/index.ts
utils.status.show({
// Optional. Default to the extension’s name followed by a generic title.
title: "Main title",
// Required.
summary: "Message below the title",
// Optional. Empty by default.
text: "Detailed information shown in a collapsible section",
Only one status is shown per build event handler. Calling utils.status.show() twice overrides the previous status.
This is meant for successful information. Errors should be reported with utils.build.* instead.
Asynchronous code can be achieved by using async methods:
src/index.ts
extension.addBuildEventHandler("onPreBuild", async ({ utils }) => {
try {
await doSomethingAsync();
} catch (error) {
Any thrown Error or rejected Promise that is not handled by utils.build will be shown in the build logs as a build event handler bug.
src/index.ts
// Any error thrown inside this function will be shown
// in the build logs as a build event handler bug.
Build event handlers end as soon as their methods end. Therefore you should await any asynchronous operation. The following examples show invalid code and the way to fix it.
src/index.ts
// Example of how to use callbacks.
const { promisify } = require("util");
// VALID EXAMPLE: please use this.
// This callback will be awaited.
extension.addBuildEventHandler("onPostBuild", async ({ utils }) => {
const response = await promisify(doSomethingAsync)();
console.log(response);
// INVALID EXAMPLE: do not use this.
// This callback will not be awaited.
extension.addBuildEventHandler("onPostBuild", ({ utils }) => {
doSomethingAsync((error, response) => {
src/index.ts
// Example of how to use events.
import pEvent from "p-event";
// This event will be awaited.
const emitter = doSomethingAsync();
emitter.start();
const response = await pEvent(emitter, "response");
// This event will not be awaited.
emitter.on("response", (response) => {
emitter.start();
src/index.ts
// Example of how to use `Array.map()`.
await Promise.all(
array.map(async () => {
array.forEach(async () => {
Got it!
