Skip to content
Debug and test edge function injection
While developing an extension that injects edge functions, you can test it locally to check if it works as expected. You also have the option of configuring your code editor for a better edge function development experience.
You can only test edge functions after you inject them into a project
Since edge functions are created within your extension, the only way to test them is by adding your extension and injecting the edge functions into a test project first. Once you run that test project, you can invoke edge functions while the project runs, as documented below. There is no way to test them in isolation.
To test your extension, you need to prepare a test project and then run netlify dev or netlify build to inject the edge functions.
  1. Have a test project repository and your extension repository on your local machine.
  2. Create a test project on Netlify.
  3. Install the Netlify CLI with npm install netlify-cli -g.
  4. Make sure your test project is a git repository by running git init in the root of your test project.
  5. Log in to your Netlify account with netlify login.
  6. Link your local test project to the test project you created on Netlify by running netlify link.
  7. Create a netlify.toml file in the root of your test project with the following configuration. Make sure to update the name to match your extension’s slug and the path to specify the location of the extension on your local machine.
netlify.toml
# Use your extension’s slug as the name
[[integrations]]
name = "my-extension"
[integrations.dev]
# Set the "path" as the path from your test project to your extension’s build folder.
path = "../path/to/extension/repository"
# The following forces the extension to be used when building the test project.
force_run_in_build = true
Now that your test project is ready, you can test your extension and the edge functions locally. To do so, run the following command for your test project in your terminal:
netlify dev
Netlify will inject the edge functions from your extension into the project during the onPreDev build event and then start a development environment that executes edge functions on local requests.
You can then invoke and debug the edge functions on your test project by making a request to the appropriate project path for each edge function. Learn more about testing and debugging edge functions locally.
If you only want to test the injection step, you can run the following in your terminal:
netlify build --context=dev
This runs a build of your test project. Netlify will inject the edge functions from your extension into the project during the onPreBuild build event.
When you make changes to your extension’s edge functions, you can check the results in your terminal by re-running the build command. Any console.log statements will show in the terminal.
Note that if your extension includes custom build event handlers that run onPreBuild or onPreDev, Netlify injects the edge functions before your build event handlers run.
If you use Visual Studio Code, we recommend that you configure your editor for a better Edge Functions development experience.
Netlify Edge Functions use a runtime based on Deno and configuring your editor will reveal runtime-related feedback on your edge function files. The SDK will prompt you to do this configuration automatically when you create your extension. If you miss the prompt, you can also install the runtime directly from Deno.
If you answer yes to the prompt, the SDK will automatically install the runtime and update your .vscode/settings.json. Make sure the deno.enablePaths value in the configuration file points to your edge functions folder and matches the path you provide to the addEdgeFunctions method:
"testing.automaticallyOpenPeekView": "never",
"deno.enable": true,
"deno.enablePaths": ["./my-extension/src/edge-functions/"],
"deno.unstable": true
If you use a different code editor, we recommend investigating whether a similar extension is available for use.
Got it!
