Skip to content
Values and methods for API Handlers
API handlers are passed a context object that lets your integration interact with the Netlify API and the Integration API. The context object extends the Netlify Serverless Functions context with additional methods and properties specific to integrations.
context.client
One of the arguments passed to the handler function is a client object within the context object. This client provides interfaces that allow you to do the following:
  • interact with the Netlify API or the Integration API
  • read and modify integration state relating to the current site or team
For information about available methods, review the NetlifyIntegrationClient API reference.
context.siteId
siteId - undefined | string
The siteId is the unique identifier for the site that is using the integration. If the integration is used on a team level, siteId will be undefined. You need this ID to interact with the Netlify API or the Integration API for things that are site-scoped.
context.teamId
teamId - string
The teamId is the unique identifier for the team that is using the integration. You need this ID to interact with the Netlify API or the Integration API for things that are team-scoped.
